And my issue is hot/cold start issues if sitting in the sun and it’s hot outside.. Sort of 28-29 degrees ambient temperature or above
Ohhhh is that under the engine address in my scan? Here is a screenshot of it.
That's the current ecu software version for that engine unfortunately...no update available.
Was worth checking.
What does the throttle body look like? Does it open up to 100%?
What does the intake look like in terms of carbon deposits?
I assume the 3490 is the software version? My throttle body was cleaned the first time it was taken in for the issue but didn’t help. I was also suspecting carbon build up in the intake but I haven’t removed and inspected that yet. Would ambient heat really have an affect on the affect of carbon build up?
Surely the OP is getting email notifications about all this action that his thread is getting.......
Oh thanks for the help too mate. I’ll keep searching.
Are you down on power at all once it does start?
Possible vacuum leak?
For what it's worth I have the same engine with 3488 ECU software and (touch wood) have never had any starting issues in any sort of ambient temperature.
