Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: R36 dsg whine
    May 2011
    Melbourne, VIC
    I had what sounds like it might be the same or at least a similar problem earlier this year with my 2007 V6 Passat. At 32K (yes, the car has very low km's for a 2007 model - we don't drive it much) a whining noise started coming from the transmission. It was subtle. I took it to the VW dealer who does all of my servicing and the head of their service department test drove it. I had a call back later that day saying there was definitely a problem with the DSG. The car was well and truly out of warranty despite teh fact that it only had 32K on the odometer. A few days later they informed me that the transmission would be replaced at no cost to me, which to their credit it subsequently was. Note I am the first owner, I drive like a bank manager and I am meticulous in its maintenance. The car has a full VW service history. I must admit that having had this experience and then this week hearing all the media reports about DSG problems, I'm now somehwat nervous about the car.
    Dec 2009
    Paddington NSW
    Quote Originally Posted by shakespeare View Post
    Had the VW specialist listen to the whine this morning and he advised that it might not be anything serious however as mine still has warranty it would be worth getting A VW dealer to check it. He mentioned that if it was whining in all gears then it could be bearing related.
    I'll get it into a dealer soon to get checked and will keep you posted.
    Sent from my iPad using Tapatalk HD
    Please do mate, good luck with it too.
    We had the car at VW for 4 days and what did they end up fixing..... nothing. But they admited that there was a sound and they would look in to it. I believe they are trying to run out the 3 month warranty that comes with all 2nd hand cars purchased from dealers as any cost of repair is at the dealers expense.
    On the 1st day of having the car they tried to spin my dad saying the car had bent the axels and wheels on the back and this was the cause of the whining. Thank god my dad is no dumb ass and called their bluff.
    They said during the 4 days they had the car they got another r36 in and it had the same sound. So there is nothing to worry about.
    What to do in this situation. Since we have lodged that there is a problem and it has been noted, can we claim on their warranty after the 3 months if a problems occurs?
    No point in naming and shaming the dealer as VW is up **** creek with out a paddle atm.
    I
    Dec 2009
    Paddington NSW
    Quote Originally Posted by nicholas128 View Post
    That's a great news storey that one. Good on them for doing what is right.
    i wouldn't worry about this media BS. A big part of the problem is that VW pulled their advertising from Fairfax, since then they have gone on a rampage against VW. and so far it's working.
    Feb 2010
    South Perth, WA
    Quote Originally Posted by Marcotto View Post
    I
    FYI had it in at a VW dealer last week and it appears that my whine is normal! I'm going to see if can go for a spin in another R36 and clarify this. Will keep you posted.
    Chris
    WLF127
    Jun 2011
    Sydney NSW
    You can do some checks to try and narrow it down.
    All gearboxes will whine to some degree as the action of teeth against teeth will cause this. This is why gears have a helix angle to make the tooth engagement more progressive.
    Does the whine happen on drive or overrun?
    Does it happen to the same degree in all gears?
    If you can find out which ratio is effectively straight through, see if the whine is present there as well.
    These tests will try and narrow it down to a particular gear set or the differential gears.
    May 2015
    Apologies for dredging up an old thread but I couldn’t find too much on this subject - DSG whine.
    My R36 wagon has just had its 90,000km service and the independent specialist gave it a clean bill of health and even provided a copy of the VCDS scan – no errors popped up.
    One thing that I didn’t ask about was what I think is a DSG whine. Most times when driving I don’t hear anything but on the overrun when it picks a lower gear, say going down a hill it is quite noticeable. The noisiest gear would probably be third.
    The DSG and Haldex oil changes were done at 60,000km.
    Apart from that the DSG works fine with quick and unobtrusive gear changes. No clunks at all.
    Should I be concerned?
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
    Feb 2010
    South Perth, WA
    I wouldn't be too concerned. I've since sold my R36 but it was trouble free for 3 years and the whine did not increase or change in that time. For info it was more apparent in 4th and 6th and only under mild load. Unless it get's louder or behaves differently I wouldn't worry.
    WLF127
    May 2015
    The more I think about this the more I wonder whether it may be an engine noise? The noise is only really noticeable at higher revs when the DSG downchanges. If I turn the air conditioning off then the noise lessens. My compressor has been replaced recently so maybe it is the accessory belt or a pulley or something?
    I should get it checked out...
