Results 1 to 7 of 7
Thread: R36 Coolant Change
Passat R36 R36 Coolant Change 16-11-2015, 02:03 PM
Umai Naa!! I just pull the temp sensor... 16-11-2015, 02:37 PM
Passat R36 OMG! Sounds too easy, any... 16-11-2015, 03:19 PM
Umai Naa!! Yeah, just put the O-ring... 16-11-2015, 03:53 PM
Passat R36 Really appreciated! Very... 16-11-2015, 09:51 PM
maddoglee Have you guys got any tips on... 25-04-2019, 03:04 PM
IanPGonzaga Start the engine and start... 01-05-2019, 08:34 PM
    Jul 2013
    Hills District
    R36 Coolant Change
    I am planing to change the coolant for my R36. I searched internet and have not found any info regarding the radiator drain plug. So i jacked the car up and had a look. Apparently there is no drain plug, the hose needs to be pulled to drain.
    So Question: Do I disconnect the RED arrow part or BLUE arrow part? Thanks.
    R36 Coolant Change-566b13bce3510db6_zpsgjmtzao9-jpg
    Dec 2008
    Sydney/Canberra
    I just pull the temp sensor out (by removing the green circlip). Just make sure you retrieve the O-ring.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2013
    Hills District
    Quote Originally Posted by Umai Naa!! View Post
    OMG! Sounds too easy, any tricks there? easy to put the Oring back and reinstall? Thanks!!!
    Dec 2008
    Sydney/Canberra
    Yeah, just put the O-ring back on the sensor and push it back in, then reinstall the circlip.
    Those quick-release couplers on the radiator hose itself, can be a pain to get off, and then back on again.
    '01 Beetle 2.0
    Jul 2013
    Hills District
    Really appreciated! Very helpful as always!
    Apr 2019
    Have you guys got any tips on bleeding the system after flushing the coolant?
    May 2015
    Start the engine and start pouring the coolant in - let the overflow bottle fill up and bubbles will just naturally want to come out.
