Results 1 to 8 of 8
Thread: R36 clicking from fan or vent
    Jul 2013
    SE suburbs, Vic
    I haven't been able to work out exactly what area it is coming from yet but I have a clicking or ticking sound coming from around the lower dash vicinity. It happens a minute or two after start up and will be four or five clicks at a time. It sounds like a plastic sound to me, sort of like there is a stick stuck under one of the distribution flaps to send air to a certain location. It only tends to happen on occasion in the first five minutes of driving for the day.
    When the fans and ac are off I don't get any sound. Waiting for a new pollen filter to arrive and have a bit more of a poke around then. Anyone had a similar issue?
    Dec 2008
    Sydney/Canberra
    It's normal.
    They all do it. It's just the temperature flap adjusting. If you look up how to do a Basic Setting on it, it should improve in the short term.
    Jul 2013
    SE suburbs, Vic
    Thanks heaps! I will see how the HVAC reset goes. Cheers
    Aug 2016
    SA
    We are having the same issue on ours. A bit annoying. How did you go mercury260? Any luck
    Jul 2013
    SE suburbs, Vic
    It improved marginally but you can definitely hear it. I find it a bit odd that it can't be fixed as I would have been surprised if they rolled off the showroom like that. It's starting to just become background noise now that I have owned the car for longer
    Sent from my SM-G930F using Tapatalk
    Feb 2009
    Both my old Skoda RS (mk 2) and my current Mk5 Golf GTI made/make and intermittent clicking/ticking noise from the centre console
    I just tune out to it - I think it's normal
    2006 VW Golf GTI Silver Mk5 5dr manual no options (the way nature intended) SOLD
    2012 Skoda Octavis RS wagon, race blue, red stitch interior, DSG SOLD
    2008 Skoda Octavia vRS Wagon (Mk II, pre-FL) 2.0 TFSI 147Kw 6 MT bright yellow SOLD
    Other: 2013 Mercedes B250 Sliver Command Pack panoramic roof
    Oct 2015
    Brisbane QLD
    Some cars have these noises, some are louder then others. Try and work out if it's normal operation or not.
    I have removed some vents and lubricated them and that's made a slight difference
    Jul 2013
    SE suburbs, Vic
    Now that I am setup with an obdeleven I have a fault of a static air flow flap meter. I am guessing this isn't the cause from the reading i have done but when I eventually pull everything apart to fix it I will silicone spray what I can and see how it goes.
