As long as the part number is the same, then it should be fine. The letter (F) at the end is the iteration. Anything higher (G, H .. etc) is an improved part and will work better. You can also use the same part with the same part number but a lower letter, however it might have a design problem that they later on fixed in (F). I you are buying new, always get one with highest letter.
- You may not post replies
- You may not edit your posts
Forum Rules
