Results 1 to 10 of 11
Thread: R36 Brake Woes
    Oct 2012
    Melbourne, Victoria
    R36 Brake Woes
    Hi guys,
    I've been having a very persistent (and annoying) issue with what I assume are my brakes.
    Long story short, once warmed up, I get a high pitch squealing sound emanating from the front of the car. The characteristics are,
    - Only when going <~20km/h
    - Can be whilst rolling or accelerating
    - Disappears the moment the brakes are tapped, but will re-appear once the brakes are released.
    - Hard braking a few times seems to temporarily remediate the situation, but the sound returns after not long
    The pads and rotors were replaced a touch over a year ago and there is no apparent impact on braking performance. Car has been scanned and there are no codes coming up.
    This video is pretty much exactly what's happening, inclusive of sound (may need to turn up volume).
    It is usually extremely loud and as you can imagine, not a good look for an R36
    Any thoughts?
    Gosford Central Coast NSW
    I get the exact same symptoms with my allroad but on the rear.
    I figure its the type of pad / rotor combination, just luck of what is in there. It wouldnt surprise me if it went away if I swapped pads (but I havent)
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2008
    Sydney/Canberra
    What brand pads and rotors?
    Oct 2012
    Melbourne, Victoria
    Hmm, my pads up front and at the back are different, so maybe. I wouldn't have thought the combination would make a difference if the sound occurs without braking?
    Quote Originally Posted by Umai Naa!! View Post
    DBA T3 rotors and TRW pads on the front. Rear wheels are using DBA T2s and QFM HPX pads.
    Dec 2012
    Sutherland Shire, Sydney
    So after changing the rotors and pads things were ok?
    This problem started some time later?
    I would be checking the stone guards for clearance and the wheel bearings for play
    Also check for tiny grooves in the rotors - get them skimmed
    Also check that the caliper is able to slide freely
    Finally, smear a thin layer of copper grease across the back of the brake pad
    Dec 2008
    Sydney/Canberra
    I think the answer lies in the pad/rotor combo.
    Oct 2012
    Melbourne, Victoria
    Quote Originally Posted by Martin View Post
    Thanks for the list Martin. I'll have a suss and see if any of the above makes a difference.
    It kinda of just randomly started a little bit after changing the brakes. Hard to say exactly when.
    Are you able to elaborate more on why the combination would be the cause? Not saying you're wrong, but I'm just curious why it would make a difference in this instance.
    Dec 2012
    Quote Originally Posted by MrWolf View Post
    No problem - it's just a logical check list - expect it to be non obvious but should be solvable
    Umai Naa!! is very knowledgeable and experienced
    There can be situations where specific rotor hardness and pad compound (fibre/ceramic/metal and friction level) don't work nicely together
    Dec 2008
    Sydney/Canberra
    As per above, some pad and rotor combos are just plain noisy.
    Moving away from OEM-style pads and rotors does tend to lead to this result though.
    Current favourite for R36 owners is ATE Ceramic pads, with ATE discs. While you're probably looking at around $650 fitted, for the fronts alone, they are very good on performance, low noise and low dust. This is all probably too late for you now, but maybe something to kep in mind, if you're planning long-term ownership.
    Dec 2008
    Sydney/Canberra
    Perhaps speak with your preferred workshop about getting the pads de-glazed, and having noise-reduction paste (Wurth makes a reputable one), applied to the pads and calipers?
