Need to check the fault code from the AFS module address 55. It will tell you what the issue is.
A dashboard light came on last week with a message along the lines of “Bend Light Failure AFS - Owners Manual”.
Scoured the owners manual and did not find the alert symbol anywhere, or the error message, or how to fix it.
Headlights don’t bend now when the steering wheel is turned.
Does anyone have any suggestions as to the problem and how to fix it?
Thanks in advance.
2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
Turns out it is not a bend light problem at all despite the wording of the alert. Replaced both turn light bulbs and the alert has not reappeared.
