Originally Posted by
Jakeys
That discussion will overtake this thread and spawn 5 pages. I will give you my findings, if you want to discuss further chuck me a PM and I'll have a chat with you, but I sold my Sprint Booster because I thought it was **** after testing it for a month and doing the VCDS analysis so I can't do further tests, I did keep the accelerator input graph though.
The throttle response time cannot be adjusted by either VCDS or Sprint Booster. Throttle sensor is instantaneous, it reads your input and measures it as a percentage, then obviously this is sent to the ECU and eventually to the engine. The delay is between the throttle position sensor and the actual engine and the systems involved there, it is inherent to the car. The sprint booster just attaches to the sensor, which has no measurable delay itself. The delay is elsewhere, therefore Sprint Booster cannot improve/remove it. What you can do is graph what that sensor measures in the various modes to determine exactly what the SB does and the answer is you see the race mode on the SB ramping up, up to about 80% throttle when stock is say 50% throttle, then for some reason it just flatlines at 80 until stock reaches 80% as well and then they both increase linearly. In other words, the last quarter of throttle travel, Sprint Booster does nothing. All it does is increase the percentage throttle reported to the car in the first three quarters pedal travel. You can do this without Sprint Booster using your foot.
It's fun to only need to use 50% throttle to effect 80% throttle, it makes you feel cool, but it is measurable identical to just pushing your foot a bit further. There are absolutely no other benefits to the system, including input lag. It cannot change the path of travel between the pedal and the engine, the car is the delay. The delay is not artificial/put in by VW for any reason and a little inline plug cannot change that.
