Quote Originally Posted by booba View Post
nice one. i have a full rvc kit for passat wagon if you are interested. It was left over from my passat as i wanted to option rvc however the tsunami happened and there was a camera shortage. in the end, they were able to get the passat ordered with camera so it has been spare for quite some time in storage. pm me if interested.
*edit* nevermind, i see you have a source for one, all good.
Also, on the ops issue, if it was aftermarket fitted then the positive connection needs to be hooked up to permanent power, if not then you will have intermittend ops. check ops controller pin 1 to see if it is ignition switched kl30 or not.
Hi booba, I was wondering when you might enter the discussion! I've seen from other posts that you are very technical.
About the RVC, I haven't done anything yet. I was going to source from here:
http://www.ebay.com.au/itm/Genuine-Volkswagen-Reverse-Camera-for-Golf-Wagon-Passat-Wagon-Jetta-and-Tiguan-/151015389360?ssPageName=ADME:B:EF:AU:1123
I figured that it was a very good price, he's local and would be able to fit the camera and do the VCDS programming as well. I'm not too good when it comes to automotive electrics. However I will send you a PM regarding your RVC.
As my R36 is an MY10.5 I'm presuming the OPS was a standard item? Or would it have been dealer fitted? I note that the PDC Module J446 is fitted in the right side of the luggage compartment - but I'm not keen to fiddle with it.
Whilst I have your attention, I'm not sure what Bluetooth I have. I'm yet to get all the documentation on my car and wonder whether when my car was originally sold by the dealer (June 2010) would they have fitted a 9W7 factory kit or possibly the Kufatec Fiscon? Is there any way of finding out, without trying to remove the module from under the driver's seat?
Many thanks.
