Results 21 to 30 of 32
Thread: Passat TDI running cold any ideas
  1. #21
    Dec 2015
    Newcastle NSW
    Pacific Paradise QLD
    Quote Originally Posted by drjekl View Post
    Well mine is $51.99 and comes from a well known seller according to the linked forum Sooner be sure than sorry
  3. #23
    Adelaide hills, SA
    NEW BEHR ( TH 5 75 ) VAG 2.0 TDI Thermostat Part No 1K0121113A | eBay
    Khttps://www.ebay.com.au/itm/NEW-BEHR-TH-5-75-VAG-2-0-TDI-Thermostat-Part-No-1K0121113A/273375441247?hash=item3fa672315f%3Ag%3AhW0AAOSw3HZ bC%7ECj&_sacat=0&_nkw=1K0121113A&_from=R40&rt=nc&_ trksid=m570.l1313&LH_TitleDesc=0
    Last question is that I guess i will lose most of the coolant when i open the hose so how much do I need to buy to refill it znd then have to burp it again as well Figured on pouring it in with a small gap in the hose then jamming it together when it hits the bottom.
    1 x 1.5L bottle of coolant concentrate should be enough. It make 3L of coolant. Though I’d get 2 bottles to have some spare coolant on hand.
  4. #24
    Jul 2010
    Robina Gold Coast
    Can you clamp the hose with a pair of vise grips ,this should stop any coolant from escaping ?
  5. #25
    Quote Originally Posted by ian View Post
    MAybe but they are about 35/50mm diameter
  6. #26
    Dec 2008
    Sydney/Canberra
    Use proper line clamps, if you must.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  7. #27
    Adelaide hills, SA
    Yeah, they’re quite reasonably priced these days. Certainly cheaper than the cooling system hoses.
  8. #28
    Well Im not happy. Today went for a run up to Montville and back and the B+/**$^$y temp gauge sat on 90 everywhere both up and down the hills. Yet last time I tried as said was all over the place. Cant figure it out but reckon it must have been an airlock thats come right. Have it sitting in the garage with the top off the tank to see what happens as it cools down.
    Went and ordered the new part and now seems wont need it so if anyone wants one it will be here in a few weeks LOL
  9. #29
    Adelaide hills, SA
    You should be happy, since it was an easy fix.
    Bleeding the cooling system properly is important, especially in the closed systems.
  10. #30
    Well two reasons im not happy
    1 Ive wasted $$50 on something I dont need if no 2 was done properly
    2 I spent $1500 for the dealer to do it properly.
    Hopefully it has cured it
