Few people on here with BWS engines, so I am sure they will chime in.
With mine, I don't lose any oil between services, but it is way lower KMs than yours, 150kkm, places I would check valve cover gasket leaks and PCV valve leaks; if you did the chains and gearbox, I am guessing the rear main seal was done at the same time?
