Dead coil pack?
Dead injector?
Have you scanned it for codes?
Hi Everyone
My R36 is idling a bit rough and when I accelerate the car has a little bit of a lag. I've tried the following to no avail.
- Throttle body clean with Three Bond Engine Conditioner
- TPS cleaned
- Spark Plugs changed
- Liqui Moly Fuel System Cleaner put in a tank of petrol
Has anyone else experienced this before? Any ideas of what is causing it?
Thanks for any help you can give.
Sent from my SM-G930F using Tapatalk
Dead coil pack?
Dead injector?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
It may have stored a code or two.
Some scan tools will also log a missfire counter, per cylinder which will help narrow it down.
'01 Beetle 2.0
Well that would require other test equipment like an oscilliscope, noid lights, and fuel pressure guages.
Plus you'd still need the scan tool to reset the ECU, as it's programmed to cut injectors when missfires are detected.
'01 Beetle 2.0
Hope you get it sorted mate.
Turns out I need a new PCV valve. That's something I didn't even think about.
mine does that slightly after prolonged idle periods.. a little stab of the throttle it goes away - i'm leaning towards carbon build up,
shows a missfire - but that could be carbon on a plug, a dead plug (replaced 10 months ago), or a coil pack. it shows an O2 sensor fault on my OBD11, but that would be due to unburnt fuel causing an odd reading.
Deep Black Volkswagen R36 Variant MY09
Opts: Auto Tailgate, Bluetooth, Sat Nav
Mods: OBD11 apps? It needs some
YouTube: That Car Channel
