Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: Passat Clock Spring
  1. #31
    Sunshine coast
    Thx, do you happen to know the torque spec for it when it goes back in again as well?
    132TSI Tiguan Allspace
  2. #32
    Dec 2008
    Sydney/Canberra
    No.
    I just use my best judgement. Usually as tight as I can get it, with a 1/2in dr ratchet.
    By the book, you're meant to replace the micro-encapsualted bolt, too.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  3. #33
    Sunshine coast
    Do they sell those at the VW dealer parts shop?
    The micro-encapsulated bolt i mean. I assume it's because it has some loctite on it?
  4. #34
    Dec 2008
    Sydney/Canberra
    Yes, can be sourced from VW without issue. Whether the dealer has one on the shelf is another thing. Worst case, they can get one in 1-2 days.
    '01 Beetle 2.0
  5. #35
    Sunshine coast
    There's a guy in this video YouTube that says it can be used five times. But how would you know if the garage has already undone it a few times during service? I guess the garage changes them every time.
  6. #36
    Quote Originally Posted by iampivot View Post
    Normally score the bolt each time then you know when to change it.
    Torque is supposed to be 50nm from memory...
  7. #37
    Sunshine coast
    Got a new clock spring installed, but the angle sensor seems not to be initialised; getting the 'this seems to be an uninitialised control module; valid WSC/Importer/Equipment data may be required' message in VCDS. I tried using both the current values in the module and using the suggested defaults from VCDS, but it's not working. I seem to be unable to set the WSC code to the values that were on the previous sensor: the input field is greyed out. Is there a trick to doing this programming?
  8. #38
    Dec 2008
    Sydney/Canberra
    Have you driven it yet?
    '01 Beetle 2.0
  9. #39
    Sunshine coast
    Yes. Should it usually fix itself?
  10. #40
    Sunshine coast
    It's weird, I can't get the angle sensor working. I can see the angle measurements if I go into 44 Steering Assist and select measurement, but not in 03 ABS brakes. Log file is here; Thursday,07,June,2018,18:03:46:47231 VCDS -- Windows Based VAG/VAS Emulator Run - Pastebin.com
    The new angle sensor seems to be made in 2016 and has an updated hw / sw version relative to my old one from 20123, maybe I need some other modules updated or a different angle sensor?
    Passat Clock Spring-screen-shot-2018-06-07-6-43-09-pm-jpg
