Results 1 to 10 of 54
Thread: Passat b7 sunroof doesn't work at all
Threaded View
newcomer Passat b7 sunroof doesn't... 23-12-2022, 07:31 AM
Old Navman Whilst I can't help, as I... 23-12-2022, 03:12 PM
MIG Check out fuses SC30, SA4... 23-12-2022, 03:27 PM
newcomer Thank you. Will do this in... 24-12-2022, 12:18 AM
prn31 The sunroof controller can... 24-12-2022, 10:50 AM
newcomer I rechecked all the fuses... 24-12-2022, 11:32 AM
newcomer No 3 fuse is missing. ... 24-12-2022, 07:20 PM
MIG Fuses can be missing because... 24-12-2022, 07:54 PM
newcomer It's a car I picked up... 24-12-2022, 07:57 PM
newcomer Didnt check passenger side ... 24-12-2022, 07:58 PM
newcomer New update! - Checked SCA... 08-01-2023, 10:02 AM
MIG Next, check the voltage and... 08-01-2023, 02:58 PM
newcomer Thank you. What's the... 08-01-2023, 03:47 PM
newcomer Managed to open up. Noted on... 10-01-2023, 05:09 PM
Guest001 Try each one to earth 10-01-2023, 05:43 PM
newcomer Thank you for the advice.... 10-01-2023, 05:47 PM
Guest001 From your questions I suggest... 10-01-2023, 06:12 PM
newcomer Hey everyone thank you so... 10-01-2023, 08:14 PM
MIG I was going to say that... 10-01-2023, 08:50 PM
newcomer You are right. The outer... 10-01-2023, 08:56 PM
newcomer Good lord [emoji22] this... 11-01-2023, 04:40 PM
nermal Looks like someone siliconed... 11-01-2023, 05:35 PM
newcomer Does look like silicon ... 11-01-2023, 06:03 PM
MIG Sounds like the last owner... 11-01-2023, 06:07 PM
newcomer Sorry but whats a PIA job... 11-01-2023, 06:09 PM
MIG PIA stands for Pain In the... 11-01-2023, 06:17 PM
newcomer Called 2 auto sparkys, the... 11-01-2023, 06:20 PM
newcomer More pics of the rubber seals... 11-01-2023, 06:19 PM
MIG Your electrical issue sounds... 11-01-2023, 09:01 PM
newcomer Thank you. I am happy that... 11-01-2023, 10:20 PM
newcomer Called the dealer today in... 13-01-2023, 07:34 PM
MIG :brutal: Surely that's the... 13-01-2023, 08:02 PM
newcomer Thank you MIG. I'm dedicating... 13-01-2023, 08:36 PM
newcomer Oooh have to remove the whole... 13-01-2023, 09:11 PM
MIG No, read through the... 13-01-2023, 09:12 PM
newcomer Oh sorry didn't notice that.... 13-01-2023, 09:13 PM
MIG I think paying €7 for erWin... 13-01-2023, 09:20 PM
newcomer Thank you MIG Sent from my... 13-01-2023, 10:23 PM
newcomer And I managed to remove ... 15-01-2023, 10:16 PM
newcomer The Sent from my Nokia... 15-01-2023, 10:19 PM
Guest001 Sad to say but I reckon you... 16-01-2023, 08:01 AM
newcomer Messaged him. Thank you for... 16-01-2023, 08:20 AM
MIG The VW parts department at... 16-01-2023, 09:13 AM
newcomer They are not too helpful... 16-01-2023, 12:35 PM
Guest001 Sad to say but I reckon you... 16-01-2023, 07:58 AM
newcomer That's true. I'm sure I can... 16-01-2023, 07:59 AM
Flipper Dog You will need to confirm with... 16-01-2023, 09:36 AM
newcomer Thank you so much for this... 16-01-2023, 12:33 PM
MIG The lube for the rails is G00... 16-01-2023, 09:47 AM
MIG I am not saying get the job... 16-01-2023, 12:49 PM
newcomer Will try that now Sent... 16-01-2023, 12:50 PM
newcomer Called them and they quoted... 16-01-2023, 01:01 PM
MIG Try Volkswagen & Audi Car... 16-01-2023, 01:58 PM
newcomer Found this on ebay. The... 16-01-2023, 07:40 PM
    Dec 2022
    Managed to open up. Noted on the brown earth. Which red wire should I check the voltage against?
    Thank you for all the help Passat b7 sunroof doesn't work at all
    Sent from my Nokia 8.3 5G using Tapatalk
