Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 54
Thread: Passat b7 sunroof doesn't work at all
    Dec 2022
    New update!
    - Checked SCA 30 fuse on driver side and Fuse 3 from Passenger side and both are ok
    - Cheked 80Amp fuse on slot 5 near battery terminal - that is fine too
    - Checked the system using OBDEleven - it says below
    POWER SUNROOF CONTROL MODULE
    ---No Signal/No Communucation
    Mornington Peninsula, VIC
    Next, check the voltage and ground at the sunroof controller \ motor.
    Here is what it looks like.
    2012-2014 VOLKSWAGEN PASSAT B7 SEDAN UPPER SLIDING ROOF SUNROOF GLASS MOTOR OEM | eBay
    And here is where it's located, Red 12v, brown Gnd
    Removing And Installing Sliding Sunroof Motor - Volkswagen Passat 2011 Workshop Manual [Page 245] | ManualsLib
    If you have voltage at that connector, it would most likely be the controller that's built into the motor; other tests to confirm need more advanced tools than just a multimeter.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Dec 2022
    Thank you. What's the volatahe reading I should expect
    Sent from my Nokia 8.3 5G using Tapatalk
    Dec 2022
    Managed to open up. Noted on the brown earth. Which red wire should I check the voltage against?
    Thank you for all the help Passat b7 sunroof doesn't work at all
    Pacific Paradise QLD
    Try each one to earth
    Dec 2022
    Thank you for the advice. Brown being the earth, which wires should I try from? Is the big connector with multi coloured wires
    Quote Originally Posted by newcomer View Post
    From your questions I suggest you take it to a car sparky and get it done properly before you short something out
    Dec 2022
    Hey everyone thank you so much for your guidance. At the end , I found the culprit!
    This clip was unhooked . I simply pushed it back in and now the sunroof started cranking. The shade opened . Probably will play around tommrow morning and figure it out more
    Thank you all Passat b7 sunroof doesn't work at all
    I was going to say that connector looks a bit unplugged; great work!
    Might it of been unplugged on purpose to hide another issue? Check all functions and leak test before celebrating
    Dec 2022
    You are right. The outer seals does seems very worn out and somewhat distorted
