Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Passat b7 sunroof doesn't work at all
    Dec 2022
    Hey guys, newbie here. I tried everything with my new Passat b7 sunroof.
    It doesn't move what ever I press. Checked all fuses as well. Please help
    (Covers were removed to check if there was a fuse)
    Sent from my Nokia 8.3 5G using Tapatalk
    Oct 2017
    VIC
    Whilst I can't help, as I have personally not encountered any problems with my sunroof, perhaps you might find some useful information on topic here:
    Sunroof problem | Volkswagen Passat Forum
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    Mornington Peninsula, VIC
    Check out fuses SC30, SA4 SA5.
    Have a look at page 94 in the below PDF.
    Volkswagen Passat B7 - Wiring Diagrams -vw-passat-b7-wiring-diagrams-eng.pdf
    The sunroof controller also connects to the CAN gateway via LIN, so if you have a scan tool see if it's showing any issues.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Dec 2022
    Quote Originally Posted by MIG View Post
    Thank you. Will do this in the morning. Another post said that a weak battery can cause this not to work. Can that be right
    May 2015
    The sunroof controller can fail. I had to replace mine on my R36. The switch looks a bit different on the B7 - its has a panoramic roof - than the B6 which has a conventional sunroof.
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
    Dec 2022
    I rechecked all the fuses again. Soo upset about this.
    Dec 2022
    No 3 fuse is missing.
    Fuses can be missing because options to your vehicle were never fitted from the factory; number three looks to be present in your image; do you mean 4?
    Did you check the fuse box on the passenger side?
    Is the problem something that just started, or is this a new car to you that came with the issues?
    Dec 2022
    It's a car I picked up recently from a private seller
    . He did mention the sunroof needs attention. Didn't think it will be this hard Passat b7 sunroof doesn't work at all
    Dec 2022
    Quote Originally Posted by newcomer View Post
    Didnt check passenger side
