Look up how to perform a basic set on the Climatronic module.
It'll just be a matter of pressing a combination of buttons on the control panel.
Sometimes the flap motors go out of sync.
So when I select the feet for the heater air still comes out of the drivers side face vent.
Am I correct in assuming there are solenoids that control the air direction in the air system. Where would I look to to check this issue.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Appreciate the pointers. Will let you know how go
Didn't work there is a discernable difference when you press face but it still does let air through.
Try closing the vent you dont want to blow air. The dash ones have a rotating wheel to open and close them dont they you can also press more than one button on the controls to get multi air
The vent wheel works fine but I don't know why it's only three drivers side that does it
When I pressed the buttons there lights started flashing. Then I could hear the vents changing position so assumed that it fixed itself but when I then put the foot vent in air still came out of the face vent. It's not like the vent is fully opened but it is a bit of air coming out.
No I don't believe the demistifyer was on
