Originally Posted by
weonarok
Probably a good thing the wiper blades 'flip' to prolong their life considering that they are $80 or more a pair against 'old style' blades being a couple of bucks.
With Ross Tech the 'lane changing blinkers' can be changed from off too 5 flashers.
On latter models you can also go in and change the values to make the speedometer more accurate. Mine is now spot on with my GPS.
There is also provision to correct the odometer settings (I run much larger tyres on my rok and the odometer reads low) but it needs a code that unfortunately only My VW himself appears to have.
"You don't know what you don't know"
Cheers dave
Well I do know what I do know and I know I cant get my speedo more accurate. Went to the correct place in VCDS and changed the values to every different one and no matter what I did it hasnt changed anything.
Any further asssitance would be appreciated.
