Has anyone had there flywheel replaced ? Mine is a little noisy when cold. I am assuming it is the flywheel because when put in a gear (drive or reverse) the noise totally disappears. The noise only apparent in park/neutral.
Look for Dual Mass Flywheel (DMF) failure. I have the same issue and current do not use the car as the chance of catastrophic failure is high and the damage is known to be extensive. I was told $2 - $2.5k for replacement.
