I replaced on mine (2009)with 12 button steering wheel from passat 2012. I was told that mk6 not going to work on my passat (white mfd). So i decided to go with normal one
All buttons works without problem...
Sent from my D6503 using Tapatalk
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
Still have old one (withbuttons
So.if you need, let me know
So you saying they won't work at all? I thought the volume buttons on the left and up and down on the right would work at least ,I am getting a wiring fault on vcds I was thinking I squashed some wires pushing the air bag back in place or a faulty control module?
Sent from my SM-N9005 using Tapatalk
Sorry for late replay. This job done by guys from vw central. They are veryyy helpful. Instead fidling himself with cables better ask them if they can help you. I beleive airbag not.gonna.work due different connections. Button as well..
That steering wheel was my first choice...after i got comfirmation about compatibily issue i changed it for normal 12 button steering wheel. Regards
Thanks i sent them a email, the air bag plug does fit and no fault codes ,the horn and button lights work they just do not function.
Check with them...if you need my old steering wheel, let me know
No point keep steering wheel if functionnnot works...i mean, volume up, down, bt, change songs, voice kontrol etc...but.still you can try fix it...maybe vw central can fix, not sure...
My job was done in half hour and everything works. So, good luck
Did you have a pic of yours I would like to see the alternative, I might have to sell it if I can't get it to work?
I will send pic to you soon
