Results 1 to 4 of 4
Thread: Need access to power
    Apr 2018
    NZ
    I have a 12v to 5v dual usb that I want to wire in permanently into the car which will connect to my wireless charging pad for my phone. My question is where can I hook it up to? I have a B7 Passat.
    Need access to power-usbpower-jpg
    Pacific Paradise QLD
    Use a fuse tap and hook it into either an always on or a ACC on depending on what you want One of the two in the fuse pic is always on and one is ACC Cant remember which is which but easy to find out
    CAUTION BOTH of these are actually SPARE SLOTS but have power at the bottom so you can put an addafuse in wth only a fuse it the top slot. Meter them out before you buy the addafuse because the bottom one is a standard fuse size and the top one is a Mini.
    Your car may NOT be the same Mine is a TDI Highline. There is a screw up above the fuse panel that you can attach the earth to.
    The fuses shown are unobtainable in AUS now but came from Jaycar
    You must put the addafuse in with the wire pointing UP in that fusebox as in those two only the bottom of each one has power You can see the metal in there anyway
    Apr 2018
    NZ
    Thanks for the response.
    That fuse piggyback is a good idea.
    Quote Originally Posted by Sloanie View Post
    Is the only way to do it properly in a VW as you cant splice into circuits or it will cause problems
