Use a fuse tap and hook it into either an always on or a ACC on depending on what you want One of the two in the fuse pic is always on and one is ACC Cant remember which is which but easy to find out
CAUTION BOTH of these are actually SPARE SLOTS but have power at the bottom so you can put an addafuse in wth only a fuse it the top slot. Meter them out before you buy the addafuse because the bottom one is a standard fuse size and the top one is a Mini.
Your car may NOT be the same Mine is a TDI Highline. There is a screw up above the fuse panel that you can attach the earth to.
The fuses shown are unobtainable in AUS now but came from Jaycar
You must put the addafuse in with the wire pointing UP in that fusebox as in those two only the bottom of each one has power You can see the metal in there anyway
