Results 1 to 10 of 13
Thread: MY13 Passat V6 Aircon
    Aug 2007
    Hi All,
    Just wondering if anyone has had any aircon problems in B7 Passat. I don't seem to have very efficient air con, it has trouble cooling down on especially a hot day even if i put it on Max setting. Last summer was fine i think. Jumped in the Golf 7R today and the air con was like the artic!
    I have toyed with getting it re-gassed or maybe i should take it in to be looked at by VW however i think they will just fob me off in typical vw style.
    Any suggestions? it will cost me about $165 to regas so perhaps i should try that.
    Aug 2012
    Perth WA
    Hi,
    We have a MY12 125TDI and the A/C works well even during our recent 38C+ days. It is not as cold as our Subaru, but it is more than adequate, it just takes a little longer and we always have the auto start stop deactivated. I am sure you are aware that you should run the A/C at least once a week even during winter to maintain the seals. Seeing that you live in BrizVagas, I'll guess that is not an issue
    Aug 2007
    Yep, AC is always on for brisbane winter. I am pretty sure there is something wrong somewhere so probably will just get it checked by the stealers.
    Quote Originally Posted by Amalgam View Post
    Hi,
    Dec 2015
    Newcastle NSW
    I bought my 2011 Passat from Brisbane (so I assume the previous owner used the a/C a lot) and it was 36-38 deg on the day I drove home. On a long 8-9 hr drive to Newcastle the a/C was great on auto 22 deg the fan speed was sitting on 2 bars.
    But having the car parked and trying to cool the car its hopeless... I had it on the lowest temp setting and high speed for 15-20 minutes on a trip home today and it wasn't all that cold...
    My old Mitsubishi magna use to blow out lots of cool air, I was wondering if my a/C needs regarding also!!
    Mar 2015
    Start with the simple things before re-gassing.
    - Hose the condenser through the front upper & lower grills It gets dusty pretty quickly and full with bugs on long trips. Which in turn reduces its efficiency.
    - Check & replace (if needed) the cabin filter.
    - Run the system for a while then use a thermometer and measure the air vent outlet temperature. Should be below 16 degrees.
    May 2010
    Melbourne, VIC
    Quote Originally Posted by 00100100 View Post
    If your AC is at operating temperatures with the setpoint set to 'low' and the air coming out of the vents is at 16 degrees, it's not working right. It should be in the single digits - down as low as 3-4C when you're on the move.
    Mar 2015
    Quote Originally Posted by kleung View Post
    May be I should have mentioned when not on the move
    You are right though, it is better to do it when the car is moving to get a more consistent result that is less weather dependent.
    Pacific Paradise QLD
    The VW Aircon is not a patch on either the Commondores I have owned or the Toyotas.
    Sad but true
    Jun 2012
    I've noticed ours tends to "freeze" on longer drives on hot days - similar to what my old man's XF Falcon Ute would do. After 2-3 hours of driving at open road speeds the a/c seems to stop cooling (LO) and the fans will barely move any air (max setting). Stop for lunch (30-40 mins) and the car will leave a big puddle of water from under the engine and the a/c will be working 100% again. Works fine on shorter (city) driving. Already been to the dealer last summer for an adjustment.
    2017 206 TSi R-Line
    Aug 2007
    that's what i am afraid of, the dreaded "we made an adjustment" which really means they didn't do bugger all
    Quote Originally Posted by CaseySP View Post
