My MY13 passat has started to throw a lot of errors. Initially they were intermittent, but now they are present all the time. Since there are multiple unrelated errors I'm suspecting either a wiring or gateway issue?
Any ideas to where to start looking?
Code:
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 06J 906 027 DE HW: 06J 907 309 B
Component: MED17.5.2 05 5359
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404000C24070160
Shop #: WSC 40139 959 131616
VCID: 71C70889681165C758-8025
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 -
Freeze Frame:
Fault Status: 01101111
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207312 km
Time Indication: 0
Date: 2014.07.04
Time: 10:24:01
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0∞C
Temperature: 66.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 11.938 V
Readiness: 1110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 Q HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: CU501511237286
Coding: 0000020
Shop #: WSC 01049 002 1048576
VCID: 3FA39EB16EC5C3B79E-806B
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 10
Mileage: 207312 km
Time Indication: 0
Date: 2014.07.04
Time: 10:24:10
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
Component: J104 C2 450M VD0B 0024
Revision: --H07--- Serial number: 00000005930578
Coding: 0001914
Shop #: WSC 05311 000 00000
VCID: 77D3369106753BF796-8023
2 Faults Found:
03842 - RPM Sensor Rear Right: Incorrect Signal
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 11
Mileage: 207312 km
Time Indication: 0
Date: 2014.07.04
Time: 10:24:20
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 157
Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 207312 km
Time Indication: 0
Date: 2014.07.04
Time: 10:24:30
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261216601722
Coding: 349106
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 44A9915DCF23A06FC3-8011
1 Fault Found:
13637397 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Reset counter: 11
Mileage: 206241 km
Date: 2020.01.25
Time: 10:37:31
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
Shop #: WSC 40139 959 99896
VCID: 76CD3B95017F42FF8D-8023
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
1 Fault Found:
02829 - Enabling Steering Column Lock from Steering Wheel Electronics
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 35
Mileage: 206219 km
Time Indication: 0
Date: 2014.06.17
Time: 09:59:02
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 195 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3753F69146F5FBF756-8063
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 9
Reset counter: 11
Mileage: 207312 km
Time Indication: 0
Date: 2014.07.04
Time: 10:24:20
Freeze Frame:
Voltage: 12.00 V
DD
Temperature: 57.0∞C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000310424
Coding: 0022157
VCID: 364DFB9541FF02FF4D-8063
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 59
Reset counter: 11
Mileage: 206241 km
Time Indication: 0
Date: 2014.06.17
Time: 10:37:32
Freeze Frame:
Voltage: 13.90 V
Count: 105
Speed: 82.0 km/h
Hex Value: 0x1268
Hex Value: 0x8004
Hex Value: 0x0101
