Results 1 to 6 of 6
Thread: My car got the error P029900
    Apr 2018
    NZ
    My car got the error P029900 the other day. Is there anyway to know if the turbo is failing or broken?
    Pacific Paradise QLD
    If turbo is broken you wont be going very fast. A description of the fault would help as not everyone has a Passat
    Dont jump to the conclusion that your turbo is damaged - turbos are very simple and therefore very reliable. Not saying that it might not be damaged but there are other things to check which can trigger the P0299 error code, like a boost leak from a loose hose clamp or a damaged rubber boost pipe etc.
    Apr 2018
    NZ
    Well the problem is the turbo actuator (if that's what it is called) that was found to be not working. Does anybody know what the part number is? Car is a 2012 125kw 4motion saloon
    Apr 2018
    NZ
    This is the part number I have found by googling various sites for a turbo actuator for my car 03L253010FV.
    Can somebody confirm that it is the correct part. Also is there a later version of this that I can use?
    Apr 2018
    NZ
    I have found that I can buy the part brand new on ebay at half the price of the ones advertised on sites in the UK. Then I found I could get the part even cheaper yet again off aliexpress. I am a bit skeptical about buying an engine part made in China. Should I be concerned?
