Results 1 to 5 of 5
Thread: R36 P2711 Code frequency help
    Nov 2023
    New Zealand
    Hi All,
    Long time R36 fan, finally in the market for one. A beautiful example with 113,000kms has appeared but a pre purchase check before the current owner purchased has raised a couple of questions.
    Is the P2711 with 25 occurences something to be concerned about? It seems to elude to mechatronic and clutch replacement in future.
    Any assistance much appreciated!
    TRANSMISSION ELECTRONICS
    2 Faults Present
    19143 (P2711) Unexpected mechanical gear disengagement
    UPPER LIMIT EXCEEDED
    DATE: 10.06.2022
    TIME: 10:51:21
    ODOMETER READING: 108715
    Fault priority: 0
    Malfunction frequency counter: 25
    Unlearning counter/driving cycle: 40
    Lower specified value too low
    DATE: 10.06.2022
    TIME: 10:51:21
    Fault priority: 0
    Malfunction frequency counter: 25 40
    - Unlearing counter/driving cycle:
    FOUR WHEEL DRIVE ELECTRONICS
    1 Faults) Present
    1155 CLUTCH
    MECHANICAL FAULT
    Sporadic
    TIME: 10:51:21
    Fault priority: 2
    Malfunction frequency counter: 7
    Unlearning counter/driving cycle: 141
    Nov 2023
    New Zealand
    I should also add the car drives and changes gear beautifully.
    Mornington Peninsula, VIC
    The 4x4 electronics is pretty common the “lifetime” filter clogs and burns the hydraulic pump out, fix is a filter, pump and fluid.
    What year is the car? Would this TSB match https://static.nhtsa.gov/odi/tsbs/20...24470-9999.pdf
    Being low kilometres, check the DSG and haldex services were done at the right time and kilometres
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Nov 2023
    New Zealand
    2008. Will need to check if there is history on the DSG and haldex. My research seems to think the clutches need to be replaced. Might avoid this one and keep looking
    If my memory serves me correctly, the MY09 R36s had a mid cycle update, white cluster instead of red etc if you are looking at something a bit newer feeling.
    And I may be biased, check out the B7 and CC, came in the same drivetrain as the R36
