Originally Posted by
kamold
Yep AJ supports both LIN 1.3 and LIN 2.0.
You just need to change your coding correctly to match.
From the label file:
C10,0xxx?xx: Multi-Function Steering Wheel (1-4 = LIN 1.3 / 5-8 = LIN 2.0)
C11,0 = Multi-Function Steering Wheel not installed
C12,1 OR 5 = Multi-Function Steering Wheel w/o Tiptronic and w/o Push-To-Talk (PTT) installed
C13,2 OR 6 = Multi-Function Steering Wheel with Tiptronic and no Push-To-Talk (PTT) installed
C14,3 OR 7 = Multi-Function Steering Wheel w/o Tiptronic and with Push-To-Talk (PTT) installed
C15,4 OR 8 = Multi-Function Steering Wheel with Tiptronic and with Push-To-Talk (PTT) installed
So you want the 3rd from last digit to be 6 or 8 depending how you want the mic button to work (either mute - 6, or voice control - 8 ).
