Have just completed this garage door remote switch mod. It's great and would recommend it to anyone. It's the 2nd best mod I've done apart from the Kufatec MFD add on. It's a pity I only discovered this thread when I'd already done most of the work. Others have posted a complete guide, so I won't repeat that. Here are my thoughts and recommendations to anyone else who is planning this job.
I used genuine parts ordered from a dealer.
- Switch 3C0 959 563 A REH
- Plug/connector 4D0 971 636 B
- Wires 000 979 009 EA
Wiring the remote - Disassemble the garage remote control and solder two wires where the switch would normally operate. My remote was a Gibidi Italian one. Fit a connector to the end of those wires so the remote is removable from the car later.
Wiring the connector - Insert the 4 wires 000 979 009 EA into positions 3, 4, 5 and 6 of the connector 4D0 971 636 B so that the pins seat in position. Connections 4 and 5 are for the switch that operates the remote. Connections 3 and 6 run the red LED at night. 3 is positive and 6 is negative. I used 4 wires and then cut the ends off for making the connections. This left another 4 shorter wires with connectors that were surplus, so it would have been possible to use only 2 wires and cut each in half.
The hardest step - removing the DSG gear selector. It's important to remove the selector so that the sliver surround bezel with the switches can also be removed. There seems to be many variations of DSG shift and many different methods for removal. Some selectors have to be put in R first whilst others require work in N then S. Work out which one is correct for your model.
Decide where to take power for the red LED in the switch - There are essentially 2 main choices. The 12V cigarette lighter plug or a nearby switch. The plug for the 12V lighter outlet can be opened up to reveal more of the wires (see photo) – grey is positive for the LED and the outer brown wire is negative. I chose the blue connector for the TPMS that is two positions away on the right side (on my car). This has less wires to deal with than the closest pale brown connector for park assist. The grey wire to pin 3 is positive and the brown wire to pin 6 is negative.
Joining into the LED lighting circuit - I bared some of the wire by CAREFULLY removing a section of insulation on the grey and brown wires for pins 3 and 6. Then soldered the wires for the garage door switch LED and wrapped in cloth insulation tape.
Choose a suitable location for the remote - It might be possible to slide it forward under the ash tray but I was concerned about the possibility of it moving around and making a noise. So I decided to Velcro it between the gear shift and the cup holders.
Double check everything works - Do a final check that the LED lights up and the switch operates the garage door and then reassemble the connectors onto all switches and fit the surround bezel.
Hey Mr Moderator - could we get this thread moved to Passat (B6 & B7)?
