Results 1 to 3 of 3
Thread: Low fuel pressure and misfire?
    Dec 2014
    I have a 3.2 litre V6 with 96,000km. A few times recently the engine has hiccupped and lost power briefly. On each occasion I was turning left onto a main road and accelerating away. At the time I thought it might be a fuel surge problem when the fuel tank was low or near empty. VCDS has reported a fault frequency of 5 and has logged:
    012555 - Low Pressure Fuel regulation
    P310B - 008 - Fuel Pressure Outside Specification – Intermittent
    000401 - Fuel Pressure Sensor (G247)
    P0191 - 002 - Implausible Signal – Intermittent
    Then today when accelerating up a hill, again with a low fuel tank and the car showing 30km to empty, the engine misfired and the check engine light flashed on and off for maybe 5 or 10 seconds. VCDS has determined today’s event as:
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - - Intermittent
    000773 - Cylinder 5
    P0305 - 001 - Misfire Detected – Intermittent
    000774 - Cylinder 6
    P0306 - 001 - Misfire Detected - Intermittent
    Does anyone have any thoughts regarding the root cause?
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Might be as simple as not letting the fuel get so low in the tank. Does it happen when you have more fuel in the tank?
    Dec 2014
    Hasn't happened on a healthy tank of fuel that I can recall recently. I've got a full tank now so I try to provoke it.
