Originally Posted by
Transporter
Use the diesel fuel additive evertime you fill up (not that expensive and maintains good fuel economy, so it kind of pay for itself, let alone lower maintenance costs) and you probably never have to do it again.
To void extended cranking, I use the scanner to prime the fuel system after fuel filter change.
Hi Transporter
Did not know about using diesel additive.
My B7 Passat only doing about 12~14 K annul, always serviced by local (Southern Highlands) dealer.
So what sort of additive should I use. I mostly fill up with BP diesel (I think same as truck diesel, from local depot)
MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
