A pair of narrow nose pliers will do the job, pull straight along the tab
I also.can not pull the black plastic bulb holder out. (what a stupid design). Do I suppose to pull directly? Or Do I have to twist and pull? I pull too hard the top bit of.the holder even broke.
Thank you for your reply. I've tried the plliers. however There must be something in there got stuck I put it so hard that the tip of the tap was even broken. I think i will give it a bit of wd 40 and try again. It's only the passenger side got stuck. the driver side came out, okay.
Ok. I used a pair of pliers and pulled it REALLY HARD and finally managed to get it out. What a stupid design this is. Now as you said before, hope the LEDs last longer so i dont have to go thru. this again any time soon.
