good stuff, will change when current LEDs blow out. Thanks for the info!
Just an update to this thread. I wasn't too happy with the colour of the LED's that I received. They were distinctly blue when compared to the xenon main beams so I did a little bit more searching and ended up buying these (2X Canbus Error Free 8 SMD LED Xenon HID Pure White W5W T10 501 Side Light Bulbs | eBay). They arrived today and I got a comparison shot for you. They match the xenons a lot better so I am happy. Hopefully the photo conveys this but it is certainly a better match. The LED on the left is the newer whiter version.
What a pain in the testicles that was. The design of the light is ridiculous and whoever thought the answer was those stick things was an idiot.
Anyway, in and much better![]()
| 2008 R36 Wagon | Black | Dynaudio | Auto-Tailgate | RNS510 | RVC |
When I upgraded my parkers I bought these from Super Cheap as I didn't really trust the cheaper stuff.
Also the guy's at Autobarn didn't even have this side of the phillips range so they were pretty much useless.
Hey guys
I just tried to install some LED parkers in my R36. Admittedly they are not the canbus error free version which is probably the 1st place I went wrong. Anyway when I installed the 1st one it didn't light up when I turned the lights on and a light warning came up on the dash. So i put the original bulb back in but the error is still there and the light still doesn't light up.
Is it possible I have damaged something? Or does it just require an error reset?
Help please
You may need a resistor across the terminals to get rid of the error with the LEDs. However, you may need to look at your wiring. Also, you may need to enable DRL in your computer (likely need a VCDS)
I've fitted LED DRLs to my CC and had lots of headaches to get it to work how I wanted (on all the time) but I still get errors which I ignore.
Leds have polarity- you may need to flip it around in the slot.
There should be no need to clear any fault codes- the cecm checks all the light circuits on startup. If the globe is good it should light up.
Yeah, as Kamold has said. If you are putting the original bulb back in, make sure you turn the ignition off and pull the key out, wait about ten seconds, and then put the key back in and check. I know I have had to do this before too so I know that you have to do this to "reset" the light checking diagnostics.
