Results 1 to 10 of 37
Thread: R36 Technical Information and DIY.
Threaded View
    Adelaide hills, SA
    PASSAT R36
    The word about oils first. http://www.vwwatercooled.org.au/f77/...nts-49676.html
    Enigine oil: Use the latest (highest) specification oil available. Oil is the cheapest part in your engine (drive train) and will be there for 15,000km or 1 year.
    Transmission and gear oils: Unlike engine oils the different brands of transmission fluids shouldn't be mixed and the same apply to gear oils (even if they’re the same grade and specifications). Approved or meet oil specs more about it in HERE
    Buying genuine servicing parts from the dealer and keeping the receipts may help should there be some doubts about faults related to maintenance during warranty period. For your and other road users safety, I suggest that you take your car to professional mechanic for your scheduled servicing.
    Engine
    V6 …………………….................3,597 cc
    Compression ratio.:1............12
    Bore x Stroke ………………….....89.0 x 96.4 (mm)
    Torque …………………………......350 Nm 2400-5300rpm
    Power……………………………......220kW (295bhp) @6600rpm
    Fuel ............................... 98RON Unleaded
    Transmission…………………... 6 speed DSG AWD Haldex coupling
    Suspension
    Suspension (Front)…………….. MacPherson strut with lower wishbones
    Suspension (Rear)………………. 4-link suspension
    Wheels and tyres………………235/40/18
    Wheel and tyre calculator
    Alloy wheels (Omanyt) 18 x 8” with 235/40 R18 tyres
    Performance
    Top Speed………………………... 250kmh
    Acceleration (0-100kmh)….. 5.6s (sedan), 5.8s (wagon)
    Fuel consumption L/100km……………….. Highway 8.3 ..... City 14.9 ..... Combined 10.7
    Fuel tank capacity…………………70L
    Kerb weight………………………... 1,689kg
    Min turning radius ………………..5,700mm
    Servicing parts
    Engine oil ………………………….. 5.5L VW504.00/507.00 supersedes all previous oil specifications (use only VW approved oil)
    Oil filter……………………………..
    Air filter…………………………….
    Pollen filter………………………….
    Fuel filter………………………….…
    Engine belt………………………….
    Coolant ……………………………...8.0L G12+
    DSG oil ……………………………....5.2L G 052 182A
    Haldex coupling oil……………….0.65L
    Bevel gearbox oil …………………
    Rear Diff oil ..................... 1.0L G 052 145 S2
    Power steering fluid
    Brakes
    Brake disc front (ATE 24.0125-0158.1)
    Diameter: 312mm Vented
    Finish: High-carbon Surface coated
    Brake disc thickness: 25mm
    Minimum thickness: 22mm
    Height: 49.9mm
    Centering diameter: 65mm
    Inner diameter: 146mm
    Brake pads front (ATE 13.0460-7184.2)
    Brake disc front (ATE 24.0130-0115.1)
    Diameter: 345mm Vented
    Brake disc thickness: 30mm
    Minimum thickness: 27mm
    Height: 49.9mm
    Inner diameter 140mm
    Brake pads front (ATE 13.0460-7200.2)
    Brake disc rear (ATE 24.0112-0219.1)
    Diameter: 310mm Vented
    Brake disc thickness: 22mm
    Minimum thickness: 20mm
    Height: 48.5 mm
    Inner diameter: 169mm
    Others can post but
    This thread is only for technical information about R36 I will try to keep it as short as possible and please do not make unnecessary posts in this thread. If you post here than post only technical info related to R36 and don’t be disappointed when it gets copied onto the first post and additional post will get deleted in order to keep it short and useful.
