Gateway and tpms kit plus time and coding.
Check aliexpress for pricing.
This is true.. I guess what I mean to ask is what is the associated cost to the upgrade. Mine is currently fully functional so I guess it's a different situation for me.
3d colour cluster installed today, along with new steering wheel with paddles.
Not a big change to the regular colour cluster.
I will have my originally upgraded colour cluster available once it is reset if anyone is looking to upgrade send me a message.
Do you disconnect battery while changing the steering wheel? Will the disconnection result in error codes in system?
Not sure if it would be the same for you (I have B7 Passat TDI). I didn't disconnect the battery, MFSW swap took me less than 10mins, from memory, I just had to code the paddle shifters.
Just replaced battery too, cleared all errors, only error which remained was the steering wheel, to clear this, just had to turn left and right full lock.
MY11 B7 Passat 125TDi Highline
Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
If you are only changing the steering wheel (you should as a precaution disconnect the negative terminal of the battery whenever working near airbags) then you shouldn't get any faults.
If you need to change the steering wheel control module then you'll also need to go steering angle sensor (g85) calibration. It will throw out a whole bunch of stuff until calibrated eg rvc, abs etc
Good to know, thanks.
Are you selling your R36 steering wheel? I want one to wrap it in Alcantara.
Here is a video of the new cluster in action:
I found the ACC graphics looks quite nice with the 3D cluster when you get around to retro fitting that
