Yes the issue will recur (I presume)
It's a flawed (yet still awesome) design.
You could always put some less sporty seats in. (?)
I have figured out a 'manouvre' to get in which I am hoping will prolong the new seat base's life.
I enter rearward first and then put my outside hand onto the door sill to allow me to 'vault' over the bolster.
2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
Tpms installed
Was a bit involved in terms of having to remove the rear bumper and run the cables up the front to the canbus gateway but worthwhile I think.
Can switch between PSI, Bar and kPa.
Has a table of different tyre/wheel sizes to select from.
Mine aren't in there but there is a utility available from a developer in Germany (dunt.at) to create a custom table and apply it to the TPMS control module using ODIS.
Top work! Way better than the stock one!
What does the stock TPMS do - besides telling you that you have low tyre pressures?
Kamold, what VW model does this TPMS come from?
Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.
Stock TPMS in our R36s has sensors in all four wheels. However these are not individually identified should one of them fall below the pressure threshold after you have set it by holding down the TPMS button after you fill your tyres.
It will ding and show the tyre pressure warning in the dash, then you need to go and check all your tyres.
The TPMS receiver is embedded in the Central Convenience Module (CCM) located behind the glovebox.
This TPMS high is from the B7 Passat. However the mounting point for the 3aa907538 bracket which holds the 3AA 907 273H receiver is already available on our cars (behind the rear bumper, just up above the right exhaust), so I assume this was available in other markets as far back as the 2006 introduction of the B6.
Custom data set applied to the TPMS module
This is what a warning looks like with tpms direct.
