Page 19 of 31 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 310
Thread: Kamold's R36
  1. #181
    Jul 2014
    Very impressed with all this crazy work you're doing! How much is the seat base part number?
    On the driver fatigue, how does it actually work? Back when I had a Verada, I replaced the whole cluster with one from a newer model. The new cluster had a fatigue timer in it where after a user set interval (Defaulted to an hour or something every time you started the car), it would flash a coffee warning light haha. Totally useless, but fun little touch.
  2. #182
    Yeah I'm kind of getting a bit nutty, these retrofits are addictive!
    Seat base:
    https://www.bks-tuning.com/sitzpolst-647587.html
    Its not dirt cheap but not ridiculous. I think with shipping was about $200.
    A motor trimmer told me about $150 to repair it, but I figured best bet would be original foam.
    Fatigue detection works by monitoring speed, steering angle sensor and time.
    If it detects that you might be drifting off it will ding and offer you a cup of coffee (well a picture of one in the MFD).
    I'll have to try and get it to engage next week when I'm on the freeway.
    Getting my research done for ACC, won't do it until next year so am collection all the info I need on parts, config etc.
    TPMS next week if my bracket arrives at the parts department from Singapore.
    Will at least get the wheel sensors installed as I need a wheel alignment done anyway.
  3. #183
    Jul 2013
    Hills District
    impressive work!
    What kind of trim tools do you need to do the foam swap job? Thanks!
  4. #184
    Jul 2014
    Seat base:
    Nice. Price for seat base not terrible. Didn't order via a local dealer? Might have saved you a little on the shipping, or not haha. Never know with VW. I'll never forget the over $2000 each they quoted me for the upgraded Omanyt wheels!
    Fatigue detection actually sounds useful unlike the old 'rada. I won't be doing any of these but I love hearing about you doing them, haha!
  5. #185
    Quote Originally Posted by Passat R36 View Post
    impressive work!
    Tools needed from memory:
    10mm triple square (multispline) bit to remove bolts from rails
    Small pointed tool of any description to push out the pins holding the round plastic pins holding the bottom side plastic covers
    T20 torx for various screws holding the rest of the plastic covers on to the base
    Side cutters or tinsnips to cut the hog rings holding the seat cover to the base
    Fingers to unclip plastic holding the rest of the seat cover clips, and to push and prod new foam into place and cover back over the base
  6. #186
    Quote Originally Posted by Jakeys View Post
    Shipping was only $25, would probably have cost more to come from Melbourne...
  7. #187
    Needed a wheel alignment so took the opportunity to have my new tpms pressure sensors installed.
    Note the spindle seems shorter on the new orange ones.
    The angle can be adjusted by loosening the stem from the sensor.
    Tyre place told me they are wrong and wouldn't fit...
    My rears were also pretty well gone (pirelli p1) so I got some Michelin PS4s for my fronts @220 each and moved my ps3s to the rear.
    Waiting on my tpms sensor mounting bracket to arrive so I can get it installed and cabled up...
  8. #188
    Apr 2013
    Sydney NSW
    how would you rate the difficulty of replacing the seat base, and how long did it take you?
    Mine is driving me nuts at times.
  9. #189
    Difficulty I'd rate medium took probably 3 hours.
  10. #190
    Apr 2013
    Sydney NSW
    Would you know if there is any revision on the base cushioning, eg will the issue reoccur later down the track with the replacement?
