Impressive!
I will get some photos up when I get the harness back out to finalise it. Bear with me.
Also my notes with the pinout connections etc.
Will try and do it over the weekend but have been pretty busy.
Will also post some links to the terminals I used.
My harness has ended up being a bit of a hack job given the iterations it went through while I figured out how to build it, so if it were done from scratch would be a bit neater and have fewer solder joints in it.
The spare amp has the two original connectors (grey and green), so (if following my design) would just need the connector removed from your factory amp, a couple of meters of various gauge wire, terminals etc.
Impressive!
I've not seen online anyone having done this exact upgrade.
Nermal of course did a superb writeup on his retrofit, but luckily had the older connectors making the amp install plug n play.
There is also a very good Danish (I think) guide but that was a complete install into a Passat without amp, so required full harness installation from head unit to speakers etc.
Jimmi CBX in Malaysia has possibly done one as he has done some pretty crazy retrofits like ACC, DCC etc
Mmm, I’m interested in the Dynaudio amp too! How easy is it to source the speakers? I believe doing the speaker grilles with the Dynaudio chrome trim is a pretty fiddly job.
Kamold is local to me and a top bloke - he has updated my RNS510 firmware and maps. Only problem is I would need to keep him supplied in boutique liquid amber for a couple of years to make this work for me…..![]()
Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.
You can pick up the amps and speakers from ebay, they are listed semi-regularly on ebay.de.
eg
VW Passat CC Soundsystem HIGH-END Dynaudio Verstärker amplifier Lautsprecher | eBay
You normally need to contact the sellers to arrange shipping as most will only ship to Europe.
I ended up getting mine from the US.
I've been known to work for the folding stuff too, doesn't have to be consumable![]()
My German isn't that crash hot. I note the CC Amplifier is 3C8 035 456 C but Nermal used 3C0 035 346 J in his Dynaudio retrofit and said that something about some amplifier models are not compatible, including from the CC? I note that in the Ebay listing it was a Lear amplifier, which I understand is correct. Price seems reasonable as I understand Amps can go for $800.
Seems like a pretty major project once you factor in the Dynaudio speaker covers (a must have) and all the work required to do the retrofit.
I'll remember that last comment, ha...![]()
The first three digits of the part designate which model its for 3C8=CC and 3C0=Passat.
The actual hardware is the same, save for the revision which will be minor hardware difference internally, if at all, and perhaps updated software.
But it should be compatible.
As with any kind of retrofit there are always compatibility risks, and there may well be some specific reason why that CC amp wouldn't work...
Here is the frankenharness. Just need to shrink the heat shrink
Here is the original amp connector I desoldered from the board and cut off the 90 degree bends from the pins.
And here is the ground and 12v I pulled from the fusebox on the drivers side. I used a 15amp piggyback connector in a spare slot.
Nice work!
Out of interest, where did you get the 2x plugs for the Dynaudio, seeing as you don't have the proper Dynaudio harness? Were they able to be ordered in, I take it, since you also have them for the Dynaudio amp I'm buying. Nice little bonus anyways. Having seen that I definitely reckon I will source the stock connector on a spare amp some time. It doesn't look OEM pretty but it's pretty simple and will definitely do the job and last you, very well done.
And the pic for the fuse box doesn't appear to be in the post?![]()
