So this arrived today
Fingers crossed for compatibility!
Yeah, if the inner rings get done on mine, it is good to know that you don't need to go through that bloody hinge episode again. That just about did my head in when I did my reversing camera!! I assume it is just a simple case of using those little wire splicers and clip them on. Passat R36, with regards to the DRL's it isn't hard to take the grill off and run the wire along the front bumper chassis. That way you can zip tie it to the chassis as well. Out of all the things I've done to mine, this was one of the easiest with regards to the install process.
Hmm, might have to do the inner rings!!Damn you Jakey and your cool mod!!
What car is this for?
Hint: it's the title of the thread![]()
Well, never saw a R36 comes with colour MFD.
They don't, its an upgrade![]()
....watching
Good luck with the install mate. Hope it works out for you.
Woot!
As expected, I've lost comfort and lighting controls via the MFD (now MFA+) however I can still control these via vcds.
Warning! My Rns freaked out and wanted me to input the security code after the cluster install. As mine was factory I had to 'find' the code using setconfig via the debug/multimedia port on the rns. If you don't have this make sure you have your code before installation.
And I have staging! (needle sweep at startup).
Niiice! Looks good, man. Jealous of staging for sure, would rather have that than the comfort/lighting settings as I have VCDS. Did you get any other new/lost functions on the MFA? Maybe I should put this down as a future mod, what did it cost in the end?
