Page 22 of 31 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 310
Thread: Kamold's R36
  1. #211
    Jul 2014
    This is true.. I guess what I mean to ask is what is the associated cost to the upgrade. Mine is currently fully functional so I guess it's a different situation for me.
  2. #212
    Gateway and tpms kit plus time and coding.
    Check aliexpress for pricing.
  3. #213
    3d colour cluster installed today, along with new steering wheel with paddles.
    Not a big change to the regular colour cluster.
    I will have my originally upgraded colour cluster available once it is reset if anyone is looking to upgrade send me a message.
  4. #214
    Jul 2013
    Hills District
    Do you disconnect battery while changing the steering wheel? Will the disconnection result in error codes in system?
  5. #215
    Dec 2012
    Not sure if it would be the same for you (I have B7 Passat TDI). I didn't disconnect the battery, MFSW swap took me less than 10mins, from memory, I just had to code the paddle shifters.
    Just replaced battery too, cleared all errors, only error which remained was the steering wheel, to clear this, just had to turn left and right full lock.
    MY11 B7 Passat 125TDi Highline
    Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
  6. #216
    If you are only changing the steering wheel (you should as a precaution disconnect the negative terminal of the battery whenever working near airbags) then you shouldn't get any faults.
    If you need to change the steering wheel control module then you'll also need to go steering angle sensor (g85) calibration. It will throw out a whole bunch of stuff until calibrated eg rvc, abs etc
  7. #217
    Jul 2013
    Hills District
    Good to know, thanks.
    Are you selling your R36 steering wheel? I want one to wrap it in Alcantara.
  8. #218
    Here is a video of the new cluster in action:
  9. #219
    Mar 2014
    Melbourne, Vic
    I found the ACC graphics looks quite nice with the 3D cluster when you get around to retro fitting that Kamold's R36
  10. #220
    Mar 2017
    Melbourne, Victoria
    I am now the VERY proud owner of an MY09 R36 wagon.
    Attachment 13388
    Thought I'd start a thread just to document the little mods I do along the way, as I've enjoyed reading similar threads from other members.
    Bought at >60K, in very good condition, no changes from factory:
    Biscay Blue, powered tailgate, RNS510, RVC.
    First change was just updating the RNS from the original 0900 software (!?) to 4120 with my custom partition ratios. Updated maps, added Aussietig's POI database, then an R splashscreen.
    Installed the MObridge Bluetooth unit that had been installed my Octavia from the dealer. Its almost as good as the 9w7 except that it doesn't support AVHCP, so I can't control streaming music from the steering wheel, and it doesnt show the track/title info on screen. So eventually I'll replace it.
    Next up I got an ECU and DSG tune from CPI as they had the special running with the DSG tune for free.
    Haven't had a chance to properly test it but so far so good, just a touch more urge through the band and more up at the top. DSG feels smoother in day to day driving and totally seamless in sport. Downshifts in sport also not too forceful.
    Today a few LEDs arrived.
    Installed a cheap interior set from Aliexpress
    Comprises all interior dome lights, glove box, boot and license plate (these ones didn't fit which I wasn't phased about as I have some proper ones ordered). Looks much more modern, I personally can't stand filament globes any more.
    Next I installed some T10 LEDs for the horrible yellow parkers.
    Apologies in advance for phone pics...
    Original parkers with low beams as comparison:
    Attachment 13392
    One original, one LED:
    Attachment 13393
    Both LEDs, with low beam xenons:
    Attachment 13394
    Hi,
    Just wondering which leds you used for your parkers?
    Also, do they just go straight in without any modification?
    Have been wanting to change mind as the stock yellow looks atrocious!!
    Kind Regards,
