Originally Posted by
macdub
Yes I have red MFD as MY09..I found digital speedo under Kufatec menu where other things r listed too such as oil temp etc..but its not accurate it shows 6km/h less than actual speed! also each time I start the car, I lose it and I have to set it up again..it does show speedo where the odometer reading is but only in mph, not in kmph
Is your red MFD a factory-standard model?
I have a 2008 R36 - that doesn't appear to have any of these options in the MFD (though I've just assumed they weren't there).
