Results 1 to 6 of 6
Thread: Intercooler for VW Passat 125 TDI 2009
    Dec 2013
    Western Australia
    What part number to order replacement or recommend better than stock, thanks
    Should be the same intercooler as used on the same era VW Golf.
    Standard replacement: INTERCOOLER VW PASSAT B6 CC 1,9 2,0 TDI 1,8 2,0 TSI 2005- 1K0145803B 3C0145805G | eBay
    Alloy standard aftermarket: Aluminum Intercooler For VW Golf Jetta MK5/6 Passat B6 B7 Audi A3/S3 2.0 FSI TSI | eBay
    Upgrade (there are cheaper options - starting at around $600 up to about $2000): Wagner Tuning VW MK5 MK6 1.6 2.0 TDI Golf Jetta Passat Caddy Competiti – Performance Brands
    Feb 2014
    Are you planning on a turbo upgrade too?
    I have a new one with upgraded billet impeller sitting around that *may* happen to fit your engine.. AFAIK - it's for a newer CB* engine, where mine's a BMR... it's supposed to spool up quicker and support more boost etc. It came with a graph.
    Turbocharger BV43 with Billet Impeller Upgrade
    Dec 2013
    Western Australia
    Thanks I've had stage 1 tuning done looking at stage 2 options
    Feb 2014
    Quote Originally Posted by Mylotian View Post
    Nice They're a torquie little motor.
    You may need to consider DSG upgrades too though. You probably have a DQ200, which (IIRC) is relatively limited in how much torque it can handle.
    Dec 2013
    Western Australia
    Also had the DSG done, I think mines the DSQ250 six speed, build date for car was October 2008 delivered 2009
