Results 1 to 3 of 3
Thread: Info for a 2014 VW Passat Alltrack
deadlywill Info for a 2014 VW Passat... 21-08-2024, 05:04 PM
MIG A boost or exhaust leak can... 23-08-2024, 09:15 AM
deadlywill Had it for 4 hours testing in... 27-08-2024, 08:36 AM
    Aug 2024
    Check engine light on - P219600 code on - O2 Sensor Signal Stuck Rich Bank 1 Sensor 1. Can clear the code with the Ancel VD700 but comes back a week or so later. No other codes.
    Car a bit noisier on acceleration. Still runs OK. Been strong smell of exhaust fumes if I have the drivers side window open.
    Noticed today some oil/grease covering the right side of the turbo. See pic. Can't say I saw it before or not it's pretty dark down there but found it today with a torch.
    Any ideas??
    Its going in to the mechanics but need to be better armed when going in.
    Info for a 2014 VW Passat Alltrack-img_20240821_132131778_hdr_ae-jpg
    Thanks in advance for the help.
    Mornington Peninsula, VIC
    A boost or exhaust leak can cause a rich code like that, try to pin down where it's leaking from.
    The mechanic should be able to do a smoke test if it's a harder to find leak.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Aug 2024
    Had it for 4 hours testing in the shop. They couldn't find anything wrong with it. No codes on their scan. Said he cleaned up the oil/grease bit and tightened some hoses that were a bit loose. See how it goes now.
