Did you manage to fix your misfire?
I had a similar thing when I pinched an o-ring putting the high-pressure fuel rail back on; the pressure on the rail would leak down overnight and cause a long crank in the morning. Check out the measuring block for the high-pressure fuel rail. It should sit near ~5 bar at idle and go up to ~8 bar when stopped due to the heat when the engine stops.
