Results 1 to 3 of 3
Thread: Help With VCDS output - Pre Purchase B7 Passat
    Mornington Peninsula, VIC
    Hi Everyone,
    If anyone can help me by looking over this autoscan result of a B7 Passat that I had a look at today.
    There are a few fault codes I am a little concerned about, not being up to date with the newer generations of VWs.
    I have removed the non faulty modules output.
    Code:
    Thursday,28,January,2016,17:41:16:07510
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    Ross-Tech: Home
    Mileage: 33750km-20971mi   Repair Order:
    Chassis Type: 3C (7N0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 2E 36 37 3C 42 44
              46 47 4C 4F 52 53 55 56 61 62 6C 72 77 A5
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: OK 0000
    Address 01: Engine (0-32-BWS )       Labels: None
       Part No SW: 03H 906 023 L    HW: 03H 907 309 A
       Component: 3,6 FSI EU5   H04 2758
       Revision: MFH04---    Serial number: VWZCZ000000000
       Coding: 001D0012246600000000
       Shop #: WSC 00028 028 00309
       ASAM Dataset: EV_ECM36FSI01103H906023L 002011
       ROD: EV_ECM36FSI01103H906023L.rod
       VCID: 2B5502E742186666F4-807E
    5 Faults Found:
    4330 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [032] - -
                 Freeze Frame:
    2670 - Throttle Position Sensor (G69)
              P0122 00 [096] - Signal too Low
                 Freeze Frame:
    2674 - Angle Sensor 2 for Throttle (G188)
              P0222 00 [096] - Signal Too Low
                 Freeze Frame:
    4219 - EVAP Emission Control Sys
              P0441 00 [096] - Incorrect Flow
                 Freeze Frame:
    Readiness: 0000 0000
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 BL    HW: 3AA 614 109 BL
       Component: J104   C2 450M VED6 0024
       Revision: --H07---    Serial number: 00000005749740
       Coding: 0116644
       Shop #: WSC 00028 028 00001
       VCID: 78FFEDAB0BCE1DFE49-802C
    1 Fault Found:
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 6
                        Fault Frequency: 52
                        Reset counter: 214
                        Mileage: 32997 km
                        Time Indication: 0
                        Date: 2016.01.18
                        Time: 15:53:31
                 Freeze Frame:
                        Speed: 87.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.75 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 D    HW: 1T0 035 680 D
       Component: RNS-MID       H70 4120
       Revision: AB001001    Serial number: VWZ6Z7M7179049
       Coding: 04050002010000A00010
       VCID: 2F6D16F77E001A46D8-807A
       Subsystem 1 - Part No: 7L6 919 859 G
       Component: AUNZ V5  7679
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
                007 - Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00100111
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 254
                        Mileage: 29293 km
                        Time Indication: 0
                        Date: 2015.08.10
                        Time: 12:42:58
    Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0005226079
       Coding: 0013B6
       Shop #: WSC 00028 028 00022
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 36632393895A2B8E9B-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0502
       Serial number: 00000002996772
       Coding: 010290
    1 Fault Found:
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 239
                        Mileage: 32472 km
                        Date: 2016.01.14
                        Time: 16:38:54
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 254
                        Mileage: 29293 km
                        Time Indication: 0
                        Date: 2015.08.10
                        Time: 12:42:58
    End-------------------------(Elapsed Time: 04:17)--------------------------
    Mar 2015
    Hi Mate,
    How many KM the car has done?
    The engine faults: if the car drives normal, then clear them, drive for a while and check vag com again to see if the faults come up. May be they are due to the immobilizer that stopped the engine from running at some stage which in turn caused the other 4 faults to come up. If the engine is loosing power, hesitating, or not smooth then I will be worried.
    The navigation grounding fault, I get that all the time too. It happens every time I connect MP3 Aux input in the center console. So don't worry about it.
    The Turn signal in exterior Mirror, did you change the turn signal LEDs recently? or may be someone changed it already before you bought the car. The fault frequency is 1 anyway, so if it works then don't worry about it until it completely dies and replace it.
    Hi,
    Thanks for the reply, the car has done 33,000km and is a few months out of warranty.
    Engine runs fine, but had oil residue on the intake manifold near the dipstick hole.
    No idea about the light, the owner said the mirror lift was fixed at some point.
