Results 1 to 10 of 13
Thread: Help in relation to leaking radiator
    May 2024
    boronia, victoria
    Hi everyone. I have a passat 2012 v6 wagon and just discovered a leak in the radiator. My question is this. To get the radiator out in these cars, do i have to remove the front bumper. Appreciate your help. Looked online and here for any instructions but could not find any.
    Regards
    Joe
    Jan 2015
    Melb
    I’m fairly sure you do.
    I did my b6 and had to remove the bumper anyway for headlight globes. Once the bumper was off I moved the radiator support forward to get the radiator out.
    It was also difficult to bleed the air out after it was back together.
    I did it after work one night so it wasn’t a whole day or anything.
    May 2024
    boronia, victoria
    Thanks for that, i thought so just wanted to make sure. Thanks again.
    Mornington Peninsula, VIC
    There are some pictures in my gallery from when I redid my cooling system, bumper comes off and the front carrier can be locked into the service position, while your there check for leaks at the thermostat hosing where it enters the block.
    Passat Upgrades - Google Photos
    Also do yourself a favor and buy a vacuum bleeder, as Passat my07 said bleeding air is difficult (without the right tool)
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    May 2024
    boronia, victoria
    Thanks for the reply MIG. I was thinking to do it myself but it seems lime a big job, maybe i'll ring the mechanic and get a quote and also do the water pump and hoses and upgrade some of those plastic parts as well. I 'll let you guys know how much it all cost. Thanks for the help guys much appreciated.
    May 2024
    boronia, victoria
    Help in relation to leaking radiator-passat-jpgHelp in relation to leaking radiator-passat2-jpg
    Well after some hesitation, decided to do it myself because i am a sucker for punishment. In all honesty it took me less than 2 hours, not as bad as i thought. Also broken radiator support needs changing now i time to chase part. Also thanks MIG i bought a coolant system purge tool. Thanks again now just need to get parts and put it back together again.
    Great work, it gets easier each time you put the car in the service position
    Best of luck with the reinstall.
    May 2024
    boronia, victoria
    Thanks mate. Now i am thinking i might do hoses and waterpump as well or atleast hoses any place i can get them form other than vw
    Jan 2015
    Melb
    If you’re doing the water pump I’d do the belt, tensioner and rollers too. That’s how I did it.
    You can get parts from places like European auto imports, Welch, unique auto parts, Sanwood trading,Repco (they’re linked to Welch).
    Just make sure they’re quoting on ok brands.
    A vac bleeder will definitely help.
    May 2024
    boronia, victoria
    coo,, thanks that's what i was thinking that too. I didn't think to try repco.
