1 A B7 has just over a metre between rear arches and is supposedly 1900 length with seats down and headrests stowed.
Depends on what you want to put in the rear as shortest dimension would be from top of the rear seat to the tailgate which is quite a bit less than the floor length.
As an example we couldnt get a top loader washing machine, lying down in without releasing the back seats and pushing them forward till vertical. Was also without its packing box. The rear opening is also less than 800 high over the rear sill
2 Power tailgate was a $700 option and you have to reach up and press the button in the bottom of the door to close it. Is only auto open.
3 Dont know mine is a highline and has all the options except adaptive chassis so does. Would think auto wipers are standard
4 Dont think so was part of the satnav package on mine for about $3000
Ok went and measured for you Boot floor 1010 from bottom of seatback to inside rear sill
From TOP of seat to door at same height is 890 However if you have the luggage cover in (which supports the seats)its only 750. Shape of taildoor makes length less as you go higher as well
Between the arches is 1010.
Height of opening from floor to highest point of door opening is 770 but due to curvature usable height is less. Also the sill is 45mm high so take that off in trying to put anything long in like our washing machine.
