DIY: Installing Front Footwell Lights in B7 Passat
There are a few different ways the cabling can be run and earthed for this job.
I chose to do it the easiest way which involves the least amount of panel removal and no cutting or modifying of any original panels, harness or brackets. It took around 1 hour including activation via VCDS.
I used a kit from BoldSport because it is plug and play.
Feel free to ask for more info on the install. It's really simple and looks amazing once complete.
Please read instructions carefully especially the ones in red typed on the photos.
Items needed:
BoldSport B7 Passat front footwell light kit
Electric tape
Nut, bolt and washer (for earth)
Total Cost: under $35.00
Tools needed:
VCDS (to activate the lights)
Torx bit (trim removal)
Phillips screw driver (for earth bolt)
Cable tie (or wire drawing snake)
Cable tie 4.8mm (for BCM Plug)
Torch
Side cutters
STEP 01
This step is not compulsory, I just did it for myself.
Wrap the wiring harness in electric tape. Just roll it along in a spiral motion (should take 2mins to do the lot).
STEP 02:
Remove the footwell trim, there are two hand screws which need to be released from the passenger side and 3 torx screws on the drivers side.
STEP 03:
This is the fiddly part. Fishing the route.
I used a thick cable tie because my cable snake/tongue was in my other car and I was too lazy to get it.
Feed from the passengers footwell.
There is a clear route about 3 inches away from the firewall, just poke your fingers behind the trim and feed the snake (cable tie) through until you feel it glide for about 30cm. Once it gets hard to push it would have gone behind the dead pedal, go over to the drivers footwell and push it back until you have the end of it and bring it over the trim.
The wiring harness will need to be taped to the end of the cable tie (at the drivers side) then simply pull the snake from the passengers side until about 40cm comes through.
Be sure to only tape the passengers side of the wiring harness (the plug with the least wires from it).
