Results 11 to 20 of 30
Thread: Guide: B7 Passat footwell lights
    Guide: B7 Passat footwell lights-3-jpg
    I did it!! Took me a while to fully understand the guide but it is all worth it. Thanks for the write up!
    Dec 2012
    Did you use LEDs or the standard halogens? Can you upload clear pics if they're LED? I'm thinking to swap mine but not sure..
    MY11 B7 Passat 125TDi Highline
    Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
    Jul 2009
    Man, I've had the kit for front & rear foot well lights with LED bulbs sitting here since October 2012... I'm such a procrastinator haha
    Aug 2007
    haha, same here. I had my front/rear kit since october 2012 as well. finally installed about 6 weeks ago and they look mint.
    i have the boldsport kit with 8 led modules. so bright, much better than the stock ones in the new golf r.
    Quote Originally Posted by dopey View Post
    Jul 2014
    I did this installation a while back on my 09 CC. Have the optional LEDs installed too. Does anyone else with this kit installed have an issue with the lights blinking? I also don't have control on the MFD to turn them on/off or change brightness yet footwell lights is definitely available in the light and vision option.
    Dec 2012
    I had that issue when I changed the lights to LED. Replaced the LED and the problem went away, simply faulty LEDs.
    I activated the lights and vision/conv option via VCDS
    Nov 2010
    The footwell lights will blink when you first start the car up as the car is checking for blown bulbs. Mine does it after I converted mine to LED.
    You can turn on cold diagnostics for them and they won't flicker.
    Jul 2014
    Thanks for the help guys, I had a bit of a fiddle with the footwell lights this afternoon and came to the following conclusion..
    Firstly, about six months ago, I installed the front footwell lights via the BCM and activated them via VCDS. I also coded the car to provide ambient lighting whenever the headlights are on. The footwell light setting was available on the MFD.
    I noticed that after installing the door courtesy lights (which required disconnecting the battery, possibly resetting the coding I did to provide ambient light??) the light provided by the footwell light was very dull and the brightness couldn't be controlled through the MFD. When this happened I noticed there was very slight flickering but just ignored it.
    Over the last few weeks it has been getting progressively worse so this is what I did today:
    - change the drivers side LED that was provided by Bold-Sport with the kit to another LED I had on hand. Same issue. Is the number on what appears to be the resistor a rating? (Bold-Sport LED has '301' on it and spare LED has '351')
    - I then tried the original halogen that was provided. With the door open the halogen bulb was at 100% brightness as expected, but with the door closed it was off! And the LED in the other footwell fitting was dull and flickering.
    - I then tested with a multimeter when the door was open; 13v as expected... Door closed and the voltage fluctuated between 0.15 and 0.31 volts; just enough residual voltage to light up the LED and change the brightness in conjunction with fluctuation.
    Anyway, probably all pointless information for this thread but just thought I would share my findings..
    Nov 2013
    I'm looking at doing this mod and have a couple of questions I haven't seen answered above.
    If I go with the LED version, do they dim/fade with the interior lights, or are they just on and off?
    Can I have them fully wired up before updating the VCDS, or do I wait until I'm able to program the VCDS?
