Results 1 to 3 of 3
Thread: Gear box oil change ?
    Mar 2015
    perth wa
    Hi all i have a 08 2.0t petrol and just wandering if you have to change the gear box oil or is it lifetime because im getting some harsh downshifts every now and then ,its done 150k and dont think its ever been done its also not a dsg thanks.
    Sent from my SM-G950F using Tapatalk
    The Aisin tiptronic gearboxes are supposed to be sealed for life. However they have transmission fluid in them, and it can benefit from being replaced. Worth a try however if you're starting to get some clunky shifts it's possibly the valve body is starting to go. The individual solenoids can be replaced if you really know what you're doing otherwise the valve body complete can be swapped. Or you can live with it...at least until it fails fully.
    Mar 2015
    perth wa
    Ok thanks i thought that would be the case ill just keep using it but if it gets too bad ill get the soliniods replaced
