Gateway location
Hi everyone,
Where is the can bus gateway located on a 2007 Passat?
Thanks.
In the B6, its behind the climate control. For ease of access you need to remove the head unit as well.
Simple job, just disconnect the 12 Volt.
You can search videos of ppl changing to rcd 330, or just changing their climate control.
Please ensure you record the coding before messing around with the Can bus via VCDS or other means.
Good luck
Thanks. Would’ve taken me a while to find. I looked under the dash and I couldn’t see it.
- You may not post replies
- You may not edit your posts
Forum Rules
